    Set depth of wood
    3 Posts 2 Posters 959 Views 2 Watching
    • I Offline
      ivantwohig
      I have a low polygon 3D model the I want to break apart into flat triangles and cut out of wood.
      Is there a way/plugin to set the depth of the wood and that automatically calculates the angle at the edges where two polys meet?
      E.g. if i wanted to make a cube out of 2CM thick wood it would calculate the edge angle at 45 Degrees.
      Any suggestions?
        If you get 'JointPushPull' and have a go at tweaking its settings ['borders' etc] you can get this effect Capture.PNG It doesn't separate the angled pieces... but at least you get all of the required faces you need to group them together later...
        • I Offline
          ivantwohig
          That's great. Thanks Tig.
