    Sun Shadow Problem
    13 Posts 3 Posters 962 Views 3 Watching
      bing1370
      i'm just wondering why everytime i render my scene with sun shadow when i put image outside my window the shadow will not come inside the scene, eventhough i will un tick the no receive shadow and cast shadow same thing will happen my sun shadow is not penetrating inside my scene. if i remove my image out side my window the sun shadow is coming inside my scene? can you help with this...
      thank's in advance...
        Hi Bing,
        Could you attach a simple example file here?
          bing1370
          i will but i need to to make a su model because most of my scene are big file i will try also to select small file only...
            Okay. There are issues that can only be ironed out when one can really have a look at that model.
              Where?
                bing1370
                here is a simple sample...i don't know why i can not upload the file...
                i click upload attachment then i browse my file and i click add file, nothing happen...
                • honoluludesktopH Offline
                  honoluludesktop
                  My render application does the same. Never noticed that before. Guess the only solution would be to render with all of the elements in the window, then crop the final image.
                    How big is the file?
                    If nothing works, you can upload it to anywhere and paste the link here.
                      bing1370
                      here's the file
                      http://www.sendspace.com/file/ld1diq
                        bing1370
                        here's the file
                        here's the render image in podium without my background image you will see the shadow
                        http://www.sendspace.com/file/u2em5y
                          OK, Thanks.
                          I am really stumped. That face with the background is set NOT to cast (or receive) shadows. What is that smaller face right in front of the window however? Is that some kind of emitter? That is set to DO cast (and receive) shadows. Is that not blocking the sunlight? What if you also set that not to cast shadows?
                          Also, in scene 4, the sun is coming from a direction that it cannot shine in through the window.
                          I do not use Podium so I was just hoping to find a solution with these settings only.
                          Great render though. I also saw your post in the gallery (just I was too much in the rush to comment yesterday). πŸ‘
                            bing1370
                            maybe your telling the blind curtain in my window? as you try the scene 3 there is shadow if i remove the background, but if i put back the background the shadow will not come inside my room
                              bing1370
                              i think you can try also to use the image as a glass texture then edit the opacity to 50%... just make sure that you map it properly
