    Sun Shadow Problem
    13 Posts 3 Posters 1.3k Views 3 Watching
    • GaieusG
      Okay. There are issues that can only be ironed out when one can really have a look at that model.
      • GaieusG
        Where?
        • B
          bing1370
          here is a simple sample...i don't know why i can not upload the file...
          i click upload attachment then i browse my file and i click add file, nothing happen...
          • honoluludesktopH
            honoluludesktop
            My render application does the same. Never noticed that before. Guess the only solution would be to render with all of the elements in the window, then crop the final image.
            • GaieusG
              How big is the file?
              If nothing works, you can upload it to anywhere and paste the link here.
              • B
                bing1370
                here's the file
                http://www.sendspace.com/file/ld1diq
                • B
                  bing1370
                  here's the file
                  here's the render image in podium without my background image you will see the shadow
                  http://www.sendspace.com/file/u2em5y
                  • GaieusG
                    OK, Thanks.
                    I am really stumped. That face with the background is set NOT to cast (or receive) shadows. What is that smaller face right in front of the window however? Is that some kind of emitter? That is set to DO cast (and receive) shadows. Is that not blocking the sunlight? What if you also set that not to cast shadows?
                    Also, in scene 4, the sun is coming from a direction that it cannot shine in through the window.
                    I do not use Podium so I was just hoping to find a solution with these settings only.
                    Great render though. I also saw your post in the gallery (just I was too much in the rush to comment yesterday). πŸ‘
                    • B
                      bing1370
                      maybe your telling the blind curtain in my window? as you try the scene 3 there is shadow if i remove the background, but if i put back the background the shadow will not come inside my room
                      • B
                        bing1370
                        i think you can try also to use the image as a glass texture then edit the opacity to 50%... just make sure that you map it properly
