    Split an object into sections
    2 Posts 2 Posters 402 Views 2 Watching
      jamma-pcb
      Hi all
      Does anyone know of a plugin that you select an object and split it up into sections by X amount.
      Fredo bend doesnt seem to work with the object i have so the only way I can think of is to but an intersect every X mm so it can bend it perfectly for engineering use. Its a straight piece but need it at 45 degree bend.. if anyone knows of a quick solution it would be appreciated.
      • TIGT Online
        An example of what you want to split & bend would help us greatly to advise you, as I for one don't fully grasp what you really need...
