    [request] Cline from Camera Eye to Sun
    7 Posts 3 Posters 851 Views 3 Watching
    • dereiD Offline
      derei
      Hy, I need to position a Light Emitting plane for my scene, to replace SUN for rendering, but I want to position it exactly in place of sun (to have same shadows). For that, I need an axis to point from Camera View to Sun direction. Any plugin for that? Or is possible with some code directly from ruby console?
      DESIGNER AND ARTIST DEREI.UK
      • TIGT Online
        Untried.
        model=Sketchup.active_model sdir=model.shadow_info["SunDirection"] Vector3d(0.259928, -0.492601, 0.830531) cama=model.active_view.camera ceye=cama.eye ctar=cama.target vec2=ctar.vector_to(ceye) vect=Geom::Vector3d.linear_combination(0.5, sdir, 0.5, vec2)
        Perhaps vect is the vector from the eye to the sun ?
        OR perhaps just sdir is the vector ? Test it and see...
        • Didier BurD Offline
          Didier Bur
          Just for fun, this one-line command creates a guide line from eye to sun.
          Sketchup.active_model.entities.add_cline(Sketchup.active_model.active_view.camera.eye,Geom;;Vector3d.linear_combination(0.5,Sketchup.active_model.shadow_info["SunDirection"],0.5,Sketchup.active_model.active_view.camera.target.vector_to(Sketchup.active_model.active_view.camera.eye)))
          DB
          • TIGT Online
            Thanks Didier, I knew it was some permutation of those things πŸ˜’
            • dereiD Offline
              derei
              Thank you very much for this, but it seems to be some problem. See the images.
              If I look from downside, the line is mirrored. Instead of ascending from camera eye to back, where is the sun, it goes in opposite direction.
              • TIGT Online
                Since the sun is assumed to be infinitely far away you can make a cline 'ray' from the eye in the direction of its vector thus...
                model=Sketchup.active_model svec=model.shadow_info["SunDirection"] peye=model.active_view.camera.eye clin=model.active_entities.add_cline(peye, svec) clin.end=nil clin.start=peye
                makes a ray extending from the eye to infinity...
                Here it is in one line
                model=Sketchup.active_model;svec=model.shadow_info["SunDirection"];peye=model.active_view.camera.eye;clin=model.active_entities.add_cline(peye, svec);clin.end=nil;clin.start=peye
                • dereiD Offline
                  derei
                  Thank you TIG, this is exactly what I wanted. β˜€
