    [request] Cline from Camera Eye to Sun
    7 Posts 3 Posters 811 Views 3 Watching
    • dereiD Offline
      derei
      Hy, I need to position a Light Emitting plane for my scene, to replace SUN for rendering, but I want to position it exactly in place of sun (to have same shadows). For that, I need an axis to point from Camera View to Sun direction. Any plugin for that? Or is possible with some code directly from ruby console?
        Untried.
        model=Sketchup.active_model sdir=model.shadow_info["SunDirection"] Vector3d(0.259928, -0.492601, 0.830531) cama=model.active_view.camera ceye=cama.eye ctar=cama.target vec2=ctar.vector_to(ceye) vect=Geom::Vector3d.linear_combination(0.5, sdir, 0.5, vec2)
        Perhaps vect is the vector from the eye to the sun ?
        OR perhaps just sdir is the vector ? Test it and see...
        • Didier BurD Offline
          Didier Bur
          Just for fun, this one-line command creates a guide line from eye to sun.
          Sketchup.active_model.entities.add_cline(Sketchup.active_model.active_view.camera.eye,Geom;;Vector3d.linear_combination(0.5,Sketchup.active_model.shadow_info["SunDirection"],0.5,Sketchup.active_model.active_view.camera.target.vector_to(Sketchup.active_model.active_view.camera.eye)))
          DB
            Thanks Didier, I knew it was some permutation of those things πŸ˜’
            • dereiD Offline
              derei
              Thank you very much for this, but it seems to be some problem. See the images.
              If I look from downside, the line is mirrored. Instead of ascending from camera eye to back, where is the sun, it goes in opposite direction.
                Since the sun is assumed to be infinitely far away you can make a cline 'ray' from the eye in the direction of its vector thus...
                model=Sketchup.active_model svec=model.shadow_info["SunDirection"] peye=model.active_view.camera.eye clin=model.active_entities.add_cline(peye, svec) clin.end=nil clin.start=peye
                makes a ray extending from the eye to infinity...
                Here it is in one line
                model=Sketchup.active_model;svec=model.shadow_info["SunDirection"];peye=model.active_view.camera.eye;clin=model.active_entities.add_cline(peye, svec);clin.end=nil;clin.start=peye
                • dereiD Offline
                  derei
                  Thank you TIG, this is exactly what I wanted. β˜€
