    How to divide complex curve in equal segments?
    4 Posts 2 Posters 3.2k Views 2 Watching
    • dereiD Offline
      derei
      I don't know if I should put this on Plugins section.
      Is there any method/plugin to divide a curve in equal segments?
      I need to make a chain-like component and I'm planning to use Component Stringer for that. But, as the shape is not a simple arc, but rather a bezier curve combined with lines (and maybe arcs), I need that to be divided in segments of same length.
      Thank you
      DESIGNER AND ARTIST DEREI.UK
      • simon le bonS Offline
        simon le bon
        Hi dereeei!
        No problem 😄
        You need Fredo_BezierSpline and RickWilson_Weld.rb but I guess you already have them installed.
        1)select the entire path: curve+arc+straight lignes and weld them together (a shortcut like Alt+W is very time saving) Then you have a unique curve.
        2)select this new curve, context clic and choose "convert in", submenu polyline divider or polyline segmentor. that's it 😉
        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/PolylineDiveder_3.jpg
        (if you want a progressive subdivision you can use polyline divider for animation)
        or if you want make your own: take a look here
        About Chris Component Stringer, I have made a bunch of studies around this one
        Cheers, simon.
        • dereiD Offline
          derei
          Thank you, simon le bon, I'm glad that I can do what I need wit the tools I already have.
            simon le bon
            A remark:
            Don't forget to copy/save your path before convert it in a polyline. Because depending of your division, its aspect is going to be broken (as a polyline 😒 )
            😉 simon
