    [Plugin] Curve Maker v1.2.2 - 7 March 2011
    25 Posts 14 Posters 34.8k Views 14 Watching
      max-cx
      The Curve Maker plugin has been updated to include more interactive drawing and editing options.
      You can now draw and edit a catenary, parabola, sine or cosine curve interactively.
      It's pretty much like using the rectangle tool as shown in this example video
      http://www.youtube.com/watch?v=M4QUO0PaI_E
      You can download the updated plugin from here:
      http://www.drawmetal.com/download
      Terry
      • mitcorbM Offline
        mitcorb
        Hi, max-cx:
        Thank you for sharing this information.
          jsteacy
          Awesome update, thanks!
            d12dozr
            Great update, works well! Thanks Terry πŸ‘
            http://goo.gl/f7ooYh
              Michaelv
              Terry,
              From one blacksmith (hobbyist) to another, thanks!
              I will PM you the 2 scripts to which I added the toolbar.restore line to make the toolbar remember its previous status (displayed or not) on Mac (I think on PC toolbars work differently).
              I also have everything working except parabola and catenary, which do not want to work right, it displays a tiny line, which is unrelated and not correct regardless of zoom.
              I am on Mac book pro, OS 10.5.8 and Sketchup 8.0.4810. I typically work in mm.
              Everything else works just fine.
              I can't look at the ruby because it's scrambled so I don't know what's wrong. It could be the default unit. HAHA I just checked and that's exactly what it is. If I start with an inch template instead of mm it works just fine.
              Michael
              • jarynzlesaJ Offline
                jarynzlesa
                blacksmith plugin
                i like this plugin . thanks πŸ‘ .
                http://www.vizualizaceschodiste.mypage.cz/
                • utilerU Offline
                  utiler
                  Hi Terry, It seems that the Catenary Icon is not viewing in the toolbar...? Is this the case of am I crazy??
                  Just Curious...
                    max-cx
                    Thanks to Michaelv for identifying a rather ugly "undocumented feature". The catenary and parabola logic was getting confused when the model units was something other than inches. Need to have a little talk with the QA department about that one.
                    I have also incorporated the suggestion of adding toolbar.restore to the appropriate scripts.
                    Unfortunately, Andrew, I don't have toolbar icons for the catenary or the parabola at this time.
                    Terry
                    • Gus RG Offline
                      Gus R
                      Excellent plugin Max. The update makes it even better. Now I can create curves including the common helix on the fly and they line up perpendicular to faces. πŸ‘
                      www.instagram.com/gusrobatto/
                      www.facebook.com/gusrobatto
                        dtrarch
                        max-cx
                        Just plain thank you. πŸ‘
                        A real bread and butter add-on πŸ˜„
                        We do not even have to do the math.
                        Very very nice
                        dtr
                          Very cool Plugin! 😎
                          • JClementsJ Offline
                            JClements
                            Great update. Thanks.
                            Be slick to have interactive properties for the helix tool'sw diameter and length.
                            Any possibility of entering of start and end diameter for a helix?
                              max-cx
                              John -
                              Thanks for your encouraging feedback.
                              Will the Archimedes Spiral tool provide what you are after? Using the interactive tool, you can enter two radii to establish the rate at which the diameter of the spiral grows and set the height parameter to specify how tall you want the spiral to be - essentially giving you a tapered helix. See attached figure.
                              The Archimedes Spiral option in the dialog box off the Plugins menu offers still more control because it lets you specify the radius at each of two particular numbers of turns - the first and the last in your case.
                              Terry
                                JClements
                                I must have overlooked this. Thanks for the quick reply.
                                • dereiD Offline
                                  derei
                                  Please help!
                                  I need to draw a Archimedes Spiral with this specs:
                                  inner radius: 15mm
                                  turns: 5
                                  distance between turns: 2mm
                                  I got the options panel attached here, but I get lost in it.
                                  What should I input there to have the desired result?
                                  DESIGNER AND ARTIST [DEREI.UK](http://derei.uk/l)
                                  • dereiD Offline
                                    derei
                                    ERROR !
                                    After using the plugin several times, I can't use it anymore. Every time I click OK on Parameters input box, it reappears. No error message, no error in Ruby console. It's a loop. Dialog disappear then is back... and so on.
                                    EDIT: -it happened in the model I was working in. It didn't fixed after close and open. But in new model it worked. It seems that something that was saved inside the model while using the plugin, caused the bug.
                                      max-cx
                                      Is this what you are trying to draw?
                                      Terry
                                        max-cx
                                        The most likely reason the dialog box keeps reappearing is that you have not entered a valid point for the curve origin. SU will not accept a ~ in any coordinate in a point - each value needs to be exact. The plugin could be friendlier in this regard.
                                        Terry
                                        • dereiD Offline
                                          derei
                                          Indeed I selected a guidepoint and its coordinate was with ~ . And the worse part was that if unselected it, hoping that the spiral to appear on origin, the previous value was retained in the inputbox, so I was triked again by the plugin. Maybe some fixes on that?
                                          And yes, that is what I wanted to draw... after some trials and errors I got it (about one hour of playing). But I did it in a different manner, I don't know if that was the correct approach, or yours... I just changed the values until I noticed a pattern πŸ’š.
                                          I still don't fully understand what are all that fields in inputbox. So many radii, turns, first turns, second turns... i'm dizzy 😲 . I tried to find the answer in the manual, but I couldn't.
                                            max-cx
                                            By design, the plugin remembers the previous inputs - including erroneous ones.
                                            Perhaps the interactive versions of these tools will be more to your liking. Have you tried the Curve Maker sub-menu on the Draw menu? They might also help you understand what the dialog boxes are prompting for and the additional degrees of control that the dialogs offer.
                                            Terry
                                            • 1 / 2
