    [Plugin] Curve Maker v1.2.2 - 7 March 2011
    25 Posts 14 Posters 35.1k Views 14 Watching
      max-cx
      Thanks to Michaelv for identifying a rather ugly "undocumented feature". The catenary and parabola logic was getting confused when the model units was something other than inches. Need to have a little talk with the QA department about that one.
      I have also incorporated the suggestion of adding toolbar.restore to the appropriate scripts.
      Unfortunately, Andrew, I don't have toolbar icons for the catenary or the parabola at this time.
      Terry
      http://www.drawmetal.com
      • Gus RG Offline
        Gus R
        Excellent plugin Max. The update makes it even better. Now I can create curves including the common helix on the fly and they line up perpendicular to faces. πŸ‘
        www.instagram.com/gusrobatto/
        www.facebook.com/gusrobatto
          dtrarch
          max-cx
          Just plain thank you. πŸ‘
          A real bread and butter add-on πŸ˜„
          We do not even have to do the math.
          Very very nice
          dtr
            Very cool Plugin! 😎
            • JClementsJ Offline
              JClements
              Great update. Thanks.
              Be slick to have interactive properties for the helix tool'sw diameter and length.
              Any possibility of entering of start and end diameter for a helix?
                max-cx
                John -
                Thanks for your encouraging feedback.
                Will the Archimedes Spiral tool provide what you are after? Using the interactive tool, you can enter two radii to establish the rate at which the diameter of the spiral grows and set the height parameter to specify how tall you want the spiral to be - essentially giving you a tapered helix. See attached figure.
                The Archimedes Spiral option in the dialog box off the Plugins menu offers still more control because it lets you specify the radius at each of two particular numbers of turns - the first and the last in your case.
                Terry
                  JClements
                  I must have overlooked this. Thanks for the quick reply.
                  • dereiD Offline
                    derei
                    Please help!
                    I need to draw a Archimedes Spiral with this specs:
                    inner radius: 15mm
                    turns: 5
                    distance between turns: 2mm
                    I got the options panel attached here, but I get lost in it.
                    What should I input there to have the desired result?
                    DESIGNER AND ARTIST DEREI.UK
                    • dereiD Offline
                      derei
                      ERROR !
                      After using the plugin several times, I can't use it anymore. Every time I click OK on Parameters input box, it reappears. No error message, no error in Ruby console. It's a loop. Dialog disappear then is back... and so on.
                      EDIT: -it happened in the model I was working in. It didn't fixed after close and open. But in new model it worked. It seems that something that was saved inside the model while using the plugin, caused the bug.
                        max-cx
                        Is this what you are trying to draw?
                        Terry
                          max-cx
                          The most likely reason the dialog box keeps reappearing is that you have not entered a valid point for the curve origin. SU will not accept a ~ in any coordinate in a point - each value needs to be exact. The plugin could be friendlier in this regard.
                          Terry
                          • dereiD Offline
                            derei
                            Indeed I selected a guidepoint and its coordinate was with ~ . And the worse part was that if unselected it, hoping that the spiral to appear on origin, the previous value was retained in the inputbox, so I was triked again by the plugin. Maybe some fixes on that?
                            And yes, that is what I wanted to draw... after some trials and errors I got it (about one hour of playing). But I did it in a different manner, I don't know if that was the correct approach, or yours... I just changed the values until I noticed a pattern πŸ’š.
                            I still don't fully understand what are all that fields in inputbox. So many radii, turns, first turns, second turns... i'm dizzy 😲 . I tried to find the answer in the manual, but I couldn't.
                              max-cx
                              By design, the plugin remembers the previous inputs - including erroneous ones.
                              Perhaps the interactive versions of these tools will be more to your liking. Have you tried the Curve Maker sub-menu on the Draw menu? They might also help you understand what the dialog boxes are prompting for and the additional degrees of control that the dialogs offer.
                              Terry
                                max-cx
                                The Curve Maker plugin has been updated. It can be downloaded from http://www.drawmetal.com/download
                                Given the current Length Units Format, if a guide point coordinate's value can only be approximated (i.e. it displays with ~), then Curve Maker will now display the coordinate value as a decimal length. This should mitigate the problem that dereeei experienced with the curve origin field in the input dialog.
                                Terry
                                • robertWanR Offline
                                  robertWan
                                  Does anybody have a version for SU 8?
                                  The author doesn't.
                                  Robert
                                    JClements
                                    Try the attached. Hopefully it contains all the required files.
                                    ctsMaker.zip
                                      robertWan
                                      Thank you. πŸ˜„
                                      Robert
                                        swpuagui
                                        Thank you so much!
