    โš ๏ธ Attention | Having issues with Sketchucation Tools 5? Report Here
    [Plugin] Curve Maker v1.2.2 - 7 March 2011
    25 Posts 14 Posters 30.8k Views 14 Watching
      max-cx
      The Curve Maker plugin has been updated. It can be downloaded from http://www.drawmetal.com/download
      Given the current Length Units Format, if a guide point coordinate's value can only be approximated (i.e. it displays with ~), then Curve Maker will now display the coordinate value as a decimal length. This should mitigate the problem that dereeei experienced with the curve origin field in the input dialog.
      Terry
      • robertWanR Offline
        robertWan
        Does anybody have a version for SU 8?
        The author doesn't.
        Robert
        • JClementsJ Offline
          JClements
          Try the attached. Hopefully it contains all the required files.
          ctsMaker.zip
            robertWan
            Thank you. ๐Ÿ˜„
            Robert
              swpuagui
              Thank you so much!
              • 2 / 2
