    Slow performance
    7 Posts 5 Posters 779 Views 5 Watching
      theodosia
      Hello guys..i am working from Greece and i have the same problem when i creating a scene with 3ds models which have many polygones.Scetch works so slowly and also i cannot render my scene.Why??
      my pc details:intel core i7 CPU,ram 6GB,windows 7
        mhtaylor
        I'm guessing you've gone through the suggestions on sketchup sage: https://sites.google.com/site/sketchupsage/faster/ ? I believe SketchUp is a 32 bit app and can't use more than 2gb memory.
        The Other Martin Taylor aka: The SketchUp Fanboy
          theodosia
          i tryied all the render trials for scetch up..finally i am working with render[in]because in the duration i am working with my scene i have beside the preview of the rendered scene and i am finishing faster..but the same problem.when i have a scene of 100 and up MB stucks and tells error report.the program closes.
            You could try exporting your scene to Kerkythea(free) and rendering in that. It's a studio based app so it handles large scenes with ease.
            @Martin
            SU is now LAA enabled so if you run it on 64bit systems it avails of extra RAM.
              mhtaylor
              @Martin
              Thanks for the heads up - I did try to work SU hard and monitor the amount of CPU and RAM consumed - I can't get SU to take more than half the 8gb I have installed even when it was struggling to manipulate a 500k edge model. Is there something I can do to improve this? I'm running Vista 64.
              • soloS Offline
                solo
                Theodosia, I still maintain that a studio based renderer will solve your problem.
                http://www.solos-art.com
                  @mhtaylor said:
                  ...I can't get SU to take more than half the 8gb I have installed...
                  LAA will not use as much RAM as you have on a 64 bit system just up to 4 Gb (and that seems to work for you). If LAA weren't there, it could only use 2 Gb (or with some hack, even on a 32 bit system, 3Gb but it may not be stable)
