    Artisan & Thea Render
    Scheduled Pinned Locked Moved Organic Modelling
    16 Posts 11 Posters 13.0k Views 11 Watching
    • OxerO Offline
      Oxer
      Hello,
      I'm probing the new Artisan plugin and it's fantastic, this is my first models with Artisan, African Sculptures.
      Proxy and result with Artisan
      Artisan Paint Brush
      Artisan Paint Brush
      Artisan Paint Brush
      Render with Thea
      Render with Thea
      Render with Thea
      Render with Thea
      Render with Thea
      Render with Thea
      I have found one problem with the material, i have painted the models with Paint Brush (Artisan's Tool), the UV mapping shows ok in SU but when i export the model to Thea, in the render appears in some parts quadrangular faces with a incorrect mapping.
      Problem with the UV mapping
      http://www.oxervision.blogspot.com/
      • CAntonisC Offline
        CAntonis
        Very nice indeed!
        Well done!
        • N Offline
          notareal
          You should do a report at SU2TH development forum, if you have not already done so.
          • david_hD Offline
            david_h
            How very Henry Moore of You. great models and renders. I just got THEA and I am getting the ARTISAN plugin very soon.
            Dale. . .WHAAT do you plan to do after you retire next week? 💚
            • soloS Offline
              solo
              How about joining forces with Thomthom and give us full unadulterated UV tools?
              http://www.solos-art.com
                @Oxer: any chance to see all your sculptures on your Blog? 😎
                • OxerO Offline
                  Oxer
                  I think that i have discovered the problem, if you see the model in X Rays Mode (in SU) appears the quad-faces, i understand that the problem with the mapped only affect to faces no triangulated.
                  I have triangulated all the surface and now the render works correctly, the problem were the faces no triangulated.
                  Pilou i'm preparing a megapost in my blog with my last models and renders, in a few days you will be able to see them, thanks for the interest.
                  • boofredlayB Offline
                    boofredlay
                    Very well done.
                    You need a shadow under the sculpture however.
                    • OxerO Offline
                      Oxer
                      Very well done.
                      Thanks, yes i know it, this is a simple quick render for test the uv mapping, i'll do a final render with good illumination, etc.
                      • cottyC Offline
                        cotty
                        Have you done it by hand or is there a way to influence artisan to do this? Or some other plugin?
                        my SketchUp gallery
                        • utilerU Offline
                          utiler
                          That is so simple and so beautiful, Oscar! inspiring stuff!!
                          Just Curious...
                          • cottyC Offline
                            cotty
                            I asked Dale and he replied the (amazing simple) solution:
                            I would suggest using the menu option Artisan->Triangulate prior to painting the material on the surface. It should work fine then.
                            Dale
                            I created a little example, see picture. Thank you Dale!
                            Cotty
                            Example
                            my SketchUp gallery
                            • EscapeArtistE Offline
                              EscapeArtist
                              Neat sculpture. Thanks for sharing that info about Artisan, triangulation and Thea. I didn't know that.
                                deanlegg
                                Can you tell me where menu - triangulate is please
                                  boofredlay
                                    deanlegg
                                    Thanks Boo
                                    That would have taken me forever to find
