    Artisan & Thea Render
    Scheduled Pinned Locked Moved Organic Modelling
    16 Posts 11 Posters 13.3k Views 11 Watching
    • OxerO Offline
      Oxer
      I think that i have discovered the problem, if you see the model in X Rays Mode (in SU) appears the quad-faces, i understand that the problem with the mapped only affect to faces no triangulated.
      I have triangulated all the surface and now the render works correctly, the problem were the faces no triangulated.
      Pilou i'm preparing a megapost in my blog with my last models and renders, in a few days you will be able to see them, thanks for the interest.
      • boofredlayB Offline
        boofredlay
        Very well done.
        You need a shadow under the sculpture however.
        • OxerO Offline
          Oxer
          Very well done.
          Thanks, yes i know it, this is a simple quick render for test the uv mapping, i'll do a final render with good illumination, etc.
          • cottyC Offline
            cotty
            Have you done it by hand or is there a way to influence artisan to do this? Or some other plugin?
            my SketchUp gallery
            • utilerU Offline
              utiler
              That is so simple and so beautiful, Oscar! inspiring stuff!!
              Just Curious...
              • cottyC Offline
                cotty
                I asked Dale and he replied the (amazing simple) solution:
                I would suggest using the menu option Artisan->Triangulate prior to painting the material on the surface. It should work fine then.
                Dale
                I created a little example, see picture. Thank you Dale!
                Cotty
                Example
                my SketchUp gallery
                • EscapeArtistE Offline
                  EscapeArtist
                  Neat sculpture. Thanks for sharing that info about Artisan, triangulation and Thea. I didn't know that.
                    deanlegg
                    Can you tell me where menu - triangulate is please
                      boofredlay
                        deanlegg
                        Thanks Boo
                        That would have taken me forever to find
