    Artisan & Thea Render
    Scheduled Pinned Locked Moved Organic Modelling
    16 Posts 11 Posters 13.6k Views 11 Watching
    • soloS
      Dale. . .WHAAT do you plan to do after you retire next week?
      How about joining forces with Thomthom and give us full unadulterated UV tools?
        @Oxer: any chance to see all your sculptures on your Blog? 😎
        • OxerO
          Oxer
          I think that i have discovered the problem, if you see the model in X Rays Mode (in SU) appears the quad-faces, i understand that the problem with the mapped only affect to faces no triangulated.
          I have triangulated all the surface and now the render works correctly, the problem were the faces no triangulated.
          Pilou i'm preparing a megapost in my blog with my last models and renders, in a few days you will be able to see them, thanks for the interest.
          • boofredlayB
            boofredlay
            Very well done.
            You need a shadow under the sculpture however.
            • OxerO
              Oxer
              Very well done.
              Thanks, yes i know it, this is a simple quick render for test the uv mapping, i'll do a final render with good illumination, etc.
              • cottyC
                cotty
                Have you done it by hand or is there a way to influence artisan to do this? Or some other plugin?
                my SketchUp gallery
                • utilerU
                  utiler
                  That is so simple and so beautiful, Oscar! inspiring stuff!!
                  Just Curious...
                  • cottyC
                    cotty
                    I asked Dale and he replied the (amazing simple) solution:
                    I would suggest using the menu option Artisan->Triangulate prior to painting the material on the surface. It should work fine then.
                    Dale
                    I created a little example, see picture. Thank you Dale!
                    Cotty
                    Example
                    my SketchUp gallery
                    • EscapeArtistE
                      EscapeArtist
                      Neat sculpture. Thanks for sharing that info about Artisan, triangulation and Thea. I didn't know that.
                        deanlegg
                        Can you tell me where menu - triangulate is please
                        • boofredlayB
                          boofredlay
                            deanlegg
                            Thanks Boo
                            That would have taken me forever to find
