    I need help with this metal wall panel
    renderpluginsextensions
    3 Posts 2 Posters 658 Views 2 Watching
    • kaluK Offline
      kalu
      Hi guys:
      I try to create a metal corrugated wall horizontal. I apply the material but when i make the render it does not show the metal in the right scale. I want to know where in the settings from the material editor I can scale the textures so I can see the achieve goal. I attach all the images and samples include the material.
      Thank you in advance.
      Kalu. 😎
      Corrugated_Metal_01.rar
      coruugated test.skp
      THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
        You don't have any texture in your diffuse layer. That makes VfSU scale the texture to 1"x1".
        Add a dummy texture in your diffuse channel to be able to scale and position the texture in SU.
        You can use a texture that match the material colour you want.
        Or, you can add a texture that represent your material visually and then add a white TexAColor to the transparency slot of the diffuse layer. (That will prevent the diffuse layer from being rendered, but still allow you to position the texture in SU.)
        Then you add a second diffuse layer which will be the one you see when you render.
        • kaluK Offline
          kalu
          thank you thomas always the best!!!!
