    Stucco on wall
    14 Posts 5 Posters 2.9k Views 5 Watching
    • david57D
      david57
      Same old building but im trying make a stucco wall but looks like candy.
      • KrisidiousK
        Krisidious
        I would suggest mixing up the pattern by making a couple of different but similar textures and reducing the depth of the bump map.
        By: Kristoff Rand
        • david57D
          david57
          Kristoff,
          Yes the normal map should be lowered down and have to do that.
          I dont know if this images are over saturated or not.
          I have two monitors and they show different.
          Im using a free program to make normal maps and height maps called
          SSBump_Generator_5_3.
          • KrisidiousK
            Krisidious
            I like the style and the color, I would like to see more solid surface and small areas of cracking or depth. try scaling the pattern like 500%...
            By: Kristoff Rand
            • david57D
              david57
              Yes, there are many patterns that need to be tried like making
              x and y coordinates scaled differently. Like making x longer
              then y. Lets see what i can do.
              • honoluludesktopH
                honoluludesktop
                IMO your textures are too large for the scale of the building. Think of a photograph of a similar building, and scale the texture to match the image in the photo. It may be a lot less then you currently think it is.
                http://farm1.static.flickr.com/102/311480484_c0a5f080a2.jpg?v=0
                • david57D
                  david57
                  Ok, honoluludesktop,
                  Will have to work on other models to figure that size correctly.
                  Below is a scale down and a different color. The two tone is still
                  there and dont know how to remove it but Its not as noticeable with
                  a scale down.
                  • honoluludesktopH
                    honoluludesktop
                    Looking good.
                    • Bryan KB
                      Ooohhh. Big difference. Very nice.
                      • david57D
                        david57
                        Here's one with a fine stucco surface.
                        • david57D
                          david57
                          Thanks Honoluludesktop and Bryan.
                          • focptF
                            focpt
                            Last image looks great!!
                            I'm so stuck on stucco right now! How did you do this? I'm trying to create use color in the diffuse channel, with a bump map. I can't seem to get it to work.
                            Please, any help would be so appreciated.
                            • Nathan
                              http://www.focalpointstudio.net
                            SU8, VRay 1.49
                            • david57D
                              david57
                              Here's the settings for the stuccos.
                              Maybe a texture can be baked for Sketch Up Models, I dont
                              know i havnt tried it.
                              • david57D
                                david57
                                Trees from ngPlant.
                                Need to work on something else.
                                Maybe, with something that has windows.
