    Stucco on wall
    14 Posts 5 Posters 2.6k Views 5 Watching
    • david57D Offline
      david57
      Yes, there are many patterns that need to be tried like making
      x and y coordinates scaled differently. Like making x longer
      then y. Lets see what i can do.
      • honoluludesktopH Offline
        honoluludesktop
        IMO your textures are too large for the scale of the building. Think of a photograph of a similar building, and scale the texture to match the image in the photo. It may be a lot less then you currently think it is.
        http://farm1.static.flickr.com/102/311480484_c0a5f080a2.jpg?v=0
        • david57D Offline
          david57
          Ok, honoluludesktop,
          Will have to work on other models to figure that size correctly.
          Below is a scale down and a different color. The two tone is still
          there and dont know how to remove it but Its not as noticeable with
          a scale down.
            honoluludesktop
            Looking good.
            • Bryan KB Offline
              Ooohhh. Big difference. Very nice.
              • david57D Offline
                david57
                Here's one with a fine stucco surface.
                • david57D Offline
                  david57
                  Thanks Honoluludesktop and Bryan.
                  • focptF Offline
                    focpt
                    Last image looks great!!
                    I'm so stuck on stucco right now! How did you do this? I'm trying to create use color in the diffuse channel, with a bump map. I can't seem to get it to work.
                    Please, any help would be so appreciated.
                    • Nathan
                      http://www.focalpointstudio.net
                    SU8, VRay 1.49
                    • david57D Offline
                      david57
                      Here's the settings for the stuccos.
                      Maybe a texture can be baked for Sketch Up Models, I dont
                      know i havnt tried it.
                      • david57D Offline
                        david57
                        Trees from ngPlant.
                        Need to work on something else.
                        Maybe, with something that has windows.
