    File... New (drawing)
    3 Posts 2 Posters 290 Views 2 Watching
      chloesdad
      Hi folks,
      I'm not exactly a newbie, but I've never been sure which folder a new empty .skp is loaded from under the 'File... New' menu command. I'm using SU7 Pro on a Mac. Thanks in advance.
      • TIGT Online
        It will use the current template set in Preferences > Templates and is not saved anywhere until you first 'save' it at which point it should start the save location in your last used folder...
          chloesdad
          Thanks, TIG. And thanks for ALL of you incredible plugins.
