    Mirroring
    2 Posts 2 Posters 283 Views 2 Watching
      twistedtwin
      I designed a little kitchen unit which was supposed to sit in a corner of two existing ones.
      During the process i lost the bearing on the direction of the door openings so once I finished I realized that I should have made the unit "in reverse", basically mirroring the existing design from left handed to right ended..
      Is there any way I can do so??
      I hope I explained myself on this one! πŸ˜’
      Thanks to you all in advance!
      • TIGT Online
        Select what you want mirroring and group it and move to one side.
        If they are 'axial' use the context-menu to flip - you probably what red or green axis. It can be undo it wrong.
        You can also mirror by using the Scale Tool - start stretching in the direction you want to flip and type -1.
        Relocate your grouped stuff as needed.
        There is also a Mirror Plugin that lets you Mirror about any plane you choose by three points if your orientations are non-axial... Do a Search for it in Plugins...
