    [REQ] Tool to delete faces without thickness.
    6 Posts 2 Posters 1.1k Views 2 Watching
    • bagateloB
      bagatelo
      It would be possible to create a tool to delete the edges that form a face that does not form a solid?
      In the sample image, I wish erase the blue faces.
      • TIGT
        Select the faces in question then try this on-liner type/copy+paste it into the Ruby Console + <enter>
        Sketchup.active_model.selection.to_a.each{|f|next if not f.valid? or not f.class==Sketchup;;Face; f.edges.each{|e|e.erase! if e.valid? and not e.faces[1]}}
        it does what you ask... 🤓
        • bagateloB
          bagatelo
          Yes!!! How can I make a menu for set keyboard Shortcut?
          • TIGT
            Copy+paste this code into a new file called DeleteSelectedNonSolidFaces.rb and on a restart you will get a Plugins menu item of that name - shortcut-key to that as desired...
            <span class="syntaxdefault"></span><span class="syntaxkeyword">class&nbsp;</span><span class="syntaxdefault">DeleteSelectedNonSolidFaces<br />&nbsp;&nbsp;def&nbsp;initialize<br />&nbsp;&nbsp;&nbsp;&nbsp;Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">selection</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_a</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">f</span><span class="syntaxkeyword">|</span><span class="syntaxdefault">next&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">not&nbsp;f</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">valid</span><span class="syntaxkeyword">?&nbsp;or&nbsp;</span><span class="syntaxdefault">not&nbsp;f</span><span class="syntaxkeyword">.class==</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">;&nbsp;</span><span class="syntaxdefault">f</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">edges</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">erase</span><span class="syntaxkeyword">!&nbsp;if&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">valid</span><span class="syntaxkeyword">?&nbsp;and&nbsp;</span><span class="syntaxdefault">not&nbsp;e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">faces</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">]}}<br />&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />end<br /></span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">not&nbsp;file_loaded</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">basename</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">__FILE__</span><span class="syntaxkeyword">))<br />&nbsp;&nbsp;</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">menu</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Plugins"</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">add_item</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"DeleteSelectedNonSolidFaces"</span><span class="syntaxkeyword">){</span><span class="syntaxdefault">DeleteSelectedNonSolidFaces</span><span class="syntaxkeyword">.new()}<br /></span><span class="syntaxdefault">end</span><span class="syntaxcomment">#if<br /></span><span class="syntaxdefault">file_loaded</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">basename</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">__FILE__</span><span class="syntaxkeyword">))<br />&nbsp;</span><span class="syntaxdefault"></span>
            • bagateloB
              bagatelo
              UNBELIEVABLY. Great. Thank you.
              • bagateloB
                bagatelo
                Call me little 'youngling'. I have done some modification in cleanup plugin.
                http://forums.sketchucation.com/viewtopic.php?f=323&t=22920&p=310264#p310264
