    [Plugin] Paint back faces
    7 Posts 5 Posters 9.0k Views 5 Watching
      Builder Boy
      Preforms many operations on the selected face materials. (This plugin can operate on many faces at once)
      Update: v3.0 is all wrapped up into a class, v3.0 also shows you any errors that may have occurred.
      Paint_back_faces v3.0.rb
      All my plugins
        What's the difference between the versions?
        As I mentioned in the other thread; it'd be good if you kept your code in a module. When you add stuff to the global namespace you risk clashes with other plugins.
        • dereiD Offline
          derei
          thomthom never got an answer... now I'm asking too... what is the difference between those three versions inside the archive? Which one is to be used?
          DESIGNER AND ARTIST DEREI.UK
          • V Offline
            valerostudio
            Any way to get this plugin to match the UVW coordinates of the face it's grabbing the texture from? This would be incredibly useful for converting Xfrog plants to SKP format.
              http://forums.sketchucation.com/viewtopic.php?t=18992
              • V Offline
                valerostudio
                Man Thom, you seriously kick butt. Thanks!
                • P Offline
                  pmolsen
                  It does not work properly, or else I am doing something wrong.
                  It does not preserve the orientation of the textures, especially on horizontal surfaces. They are not mirrored to the back face. They are merely painted with random orientation. Often they repeat numerous times.
