    Smooth 'feature'
    3 Posts 2 Posters 367 Views 2 Watching
    • F
      FelixofMars
      I am trying to work out if this is a bug or there is some combo key that is near to another feature and I keep hitting it by mistake.
      I am creating meshes for UDK in sketchup and I tend to keep lots of face detail, so tris. But every so often Sketchup will seemigly smooth a mesh removing most of the lines I have created. I usually undo this smooth action but sometimes its happened when I haven't realised and I save then have to either fix the object or export and OBJ and reimport then retexture it.
      I am fed up with this now, I am wasting hours now the meshes are quite complicated.
      Suggestions?
      Thanks.
      • thomthomT
        There are some bugs that cause this.
        If you have a mesh or a group with a mesh selected and minimize SU, then restore it SU smooths the mesh.
        It also seem to happen if you have something selected and SU becomes unresponsive for a while, (processing something, saving, autosaving) and when it returns the application seem to flicker and the mesh is smoothed.
        It's a very annoying behaviour that has forced me into a habit of deselecting very often.
        • F
          FelixofMars
          Cheers, so it is a known bug of sorts?
          I thought I was doing something at first by accident but it just kept happening. I will keep an eye out for that and try to avoid minimizing. Maybe its worth taking off autosave as I am used to saving often anyway thanks to using in house tools. πŸ˜„
