    Help! What is going on with this texture?
    6 Posts 3 Posters 535 Views 3 Watching
    • EdsonE
      Edson
      the first image is how it looks in sketchup.
      and this is how it renders.
      does anyone know what is going on and how to fix it?
      http://www.mahfuz.arq.br
      • D
        d12dozr
        Is it a skewed or otherwise distorted texture?
        Try this...turn on hidden geometry, right click on the texture -> Make Unique Texture
        If that doesn't work, try subdividing the face by drawing lines across it (then hide them for the render)
        http://goo.gl/f7ooYh
        • EdsonE
          Edson
          the same texture was scale twice. this must be the problem. your tip did not work: the texture rendered black. what I did that did work was to duplicate the texture, change its name and re-apply it. thanks anyway.
          • D
            d12dozr
            Glad you got it πŸ‘
            • GaieusG
              Edson,
              Was the texture not applied to a back face (and on the front face inside the wrong one)? That would explain also (and probably explain why your workaround worked).
              • EdsonE
                Edson
                @gaieus said:
                Edson,
                csaba,
                it surely could. I was using this and other context elements from several older projects thus I do not remember when I modeled that. one of the things I did was to reverse the face before trying the other steps.
