    Help! What is going on with this texture?
    6 Posts 3 Posters 345 Views 3 Watching
    • EdsonE Offline
      Edson
      the first image is how it looks in sketchup.
      and this is how it renders.
      does anyone know what is going on and how to fix it?
      http://www.mahfuz.arq.br
        d12dozr
        Is it a skewed or otherwise distorted texture?
        Try this...turn on hidden geometry, right click on the texture -> Make Unique Texture
        If that doesn't work, try subdividing the face by drawing lines across it (then hide them for the render)
        http://goo.gl/f7ooYh
        • EdsonE Offline
          Edson
          the same texture was scale twice. this must be the problem. your tip did not work: the texture rendered black. what I did that did work was to duplicate the texture, change its name and re-apply it. thanks anyway.
            d12dozr
            Glad you got it 👍
              Edson,
              Was the texture not applied to a back face (and on the front face inside the wrong one)? That would explain also (and probably explain why your workaround worked).
              • EdsonE Offline
                Edson
                @gaieus said:
                Edson,
                csaba,
                it surely could. I was using this and other context elements from several older projects thus I do not remember when I modeled that. one of the things I did was to reverse the face before trying the other steps.
