    [Plugin] Skel_animation base extension 1.01 +.02
    12 Posts 6 Posters 11.9k Views 6 Watching
    • chrisglasierC Offline
      chrisglasier
      Skel 3some.gifThis plug-in provides the means to use Matt Scarpino's Skel animation module with existing model figures. There are dialogs that open from the context (pose and new frame) and View (Run, Auto name and Auto joints) menus. Please note the Ruby_tree.rb that helps process raw SU data and selections for the Skel bones seems to throw a loading error on any version other than Sketchup v 8.
      Included are two example skps, one with four keyframes and one without. Please try them out. If everything is OK then I will explain how to make a model that can be auto-named and -jointed. (Actually I need a bit more time to finish the joint business).
      There seems to be plenty of potential in expanding on Matt's original initiative including stringing together keyframe modules - ease in starts, repeating intermediates, ease out finishes and so on.
      Edit Jan 28 2011
      I have added the revised skel_ui.rb with the auto_joints and the skp that has the upper and lower limbs and body as components (to show what is needed from any model). There is no need to name the component definitions except for the body (must be called 'body'). Use auto name and auto joints and then check with view > faces > x ray & > shaded (to see red joints inside). Joint positions will probably need some tweaking. They are nested with their limbs, so need to open/close each to adjust and test as necessary.
      edit: swapped zip - found error in pivot joints
      edit: added pix of name, joints and adjustment
      edit 1.02 observer added to clear variables pre save
      extract to SU 8 plugins folder
      QuinSkps.ZIP
      QuinSkel - components only.zip
      tree_animation 1.01.ZIP
      tree_animation 1.02.zip
      With TBA interfaces we can analyse what is to be achieved so that IT can help with automation to achieve it.
      • Rich O BrienR Online
        Thanks Chris. Gonna give this a go to see if it has other uses. Looks very impressive πŸ‘
          driven
          hi Chris,
          hope your keeping well,
          'mostly' working on the 'Mac',
          after the first run parts can end up 'hidden', and although you can use 'unhide all' to get them back and then continue, it can lead to SU crashing...
          john
            chrisglasier
            Thanks for the test results.
            Can I explain the hidden business? The Skeleton is made from the component definitions and transformations of an old exploded skeleton (pose) or the master (first pose and run). Immediately before the skeleton is formed these templates are hidden. After the animation is complete the skeleton is exploded (pose) or erased (run) and the 'spent' body parts erased. Maybe you can see something there that is causing the splats. I don't seem to get them on my PC but I do notice loading and closing times are very variable, so it's obviously screwing around with SU's brains somehow.
            A bit beyond me really but I am sure it can be solved ...
            Tp
              chrisglasier
              Please see first post for additions
                Regular Polygon
                Your mannequin seems like a very useful test-model for human figure animation. I posted some more about it on my Keyframe Animation topic here.
                My SketchUp Plugins
                • iichiversiiI Offline
                  iichiversii
                  Hi Chris, just wondering have you taught about posting a tutorial video on how to set up a character for this feature, i downloaded the plugin but have no idea where to start with it
                  Bring on the Rain...
                    chrisglasier
                    I hadn't ... but as I am experimenting with using macro-type animation directly in the original interface (see demos in the lab of my website) ... I am thinking perhaps this could be another example of use.
                    Meanwhile here is a quick video. Actually the action in SU itself is very much smoother. You can see by using QuinSkel 4 frames.skp from QuinSkps.zip and base extension 1.02. Then ... View > Skel_animation > Run
                    View My Video
                    Now I need to find out how I did it!
                    • duanekempD Offline
                      duanekemp
                      Driven sent me to this thread and glad he did.
                      I'm very interested in knowing if there has been any further development on this since fall of 2011?
                      I clicked on the website link... wouldn't load (http://glasier.hk/lab.php)
                      And of course, I saw the video. Thank you for sharing with us. But can you share what the advances have been since?
                      Duane Kemp
                      Kemp Productions
                      Puidoux, Switzerland
                      Gallery:
                      https://duanekemp.artstation.com/
                        chrisglasier
                        @duanekemp said:
                        ... But can you share what the advances have been since?
                        Well this was a small foray into an area that is important to what I have been trying to achieve for ages. As an infographist you may be interested in having a look at my video channel (https://www.youtube.com/channel/UCbK31Yy8yfs81mVBaXw3DXA). I am currently working on a new entry which consolidates everything into the node-webkit approach. This means individuals can use their desktops as part of the Web something like people use their smart phones as part of telecommunications. I hope a few weeks more will allow me to explain this properly!
                          duanekemp
                          Thank you for the heads up.
                          Duane Kemp
                          Kemp Productions
                          Gallery:
                            chrisglasier
                            Here is a preview of the video I mentioned.
                            Skel appears around 3.00 in a collage showing different types of multimedia using html5 in node-webkit desktop windows instead of separately launched applications.
                            I'm a bit concerned about the soundtrack. Is it acceptable on an amateur basis?
