    Progressbar 2.0
    27 Posts 13 Posters 5.0k Views 13 Watching
    • fuzzionF Offline
      fuzzion
      @thomthom said:
      Took me the wee hours of the night. πŸ˜‰ πŸ˜„
      You are a legend mate πŸ‘
      "Only the dead have seen the end of war" - Plato
      • tpstigersT Offline
        tpstigers
        @thomthom said:
        Since Progressbar isn't release yet, the list would be: none
        That pretty much sums up all progress bars. I just can't bring myself to believe them.
        β€œI have an existential map; it has 'you are here' written all over it”
          morci429
          are CloseOpens 2.0 and the Progressbar 2.0 out yet??
          • brodieB Offline
            brodie
            Really exciting stuff! Not since Windows 98 has a progressbar been so anticipated!
            -Brodie
            Note: I'm not really sure when Windows started having it's little progress bar thing but Windows 98 seemed like the funniest version at the time of writing and I'm too lazy to research it, so I went with it.
              todd burch
              Progressbar 2.0, as I had wanted to release it, will never see the light of day beyond my computer. Scripts would have to be written to take advantage of it.
              I might (might...) release a Progressbar 1.5 though, but it too will require scripts to change (very minimally) to take advantage of a cancel feature.
              Todd
              (And yes, I've been busy with other projects - namely my day job).
              Oh, and expect CloseOpens V2 soon. All that's left is a bit of packaging and final testing.
              • H Offline
                hygicell
                Hi Guys,
                I happen to be the "Frenchman" who challenged Todd some time ago which apparently led to progressbar.rb
                except that I am Belgian, from the Flemish part (I am not a fanatic, rest assured ! πŸ˜’ ) but my last sentence will explain the difference for all to understand ! 😍
                I recognise the drawings of my lake
                Todd spent some sleepless nights, solved the issue and allowed me to try it out under a gentleman's agreement of confidentiality, which, of course, I respected
                still only closeopens v1.1 is available to the general public, which is a pity
                lately I have gotten extremely annoyed by the time it takes for sketchup to backup a file
                Microsoft Windows's task manager doesn't help either:
                invariably it shows that sketchup "does not respond", same goes for Layout:
                impossible to know if something is happening, how long it will take,
                worse: impossible to intervene without losing part of your data
                so Todd, will you please consider taking progressbar.rb to the next level?
                or does any of you wizards feel challenged to make one for the backups of Sketchup and Layout ?
                I offer a crate of the best Belgian Beer !
                thanks, Frank
                  todd burch
                  Hi Frank.
                  First, thank you so much for working with me and having a great test case from which I was able to "fix" closeopens to work more efficiently.
                  As I rewrote closeopens, the first step, as you know, was to modify progressbar to allow the user to choose to cancel the process. After I did that, I went to rewrite the algorithm used by closeopens to make it MUCH more efficient. IIRC, the processing time for your model went from INFINITY (as in, it never did finish) to 52 seconds.
                  I was excited about modifying progressbar to make it V2, and have it apply globally to all the scripts that used it, but I was not able to crack that nut without also having a requirement to also modify each and every script that called it to allow the canceling of the process. This is where Progressbar 2.0 died.
                  However, closeopens does have Progressbar 2.0 functionality built-in, and, I have stalled bring closeopens to market, for some time now. And, while some attempts have been made by me to get it ready for packaging, I have broken the new copy. This is where I stand. I need to fix it, again, and then publish it. I will do this - but cannot promise when right now. My day job is demanding, and so are extra-curricular activities.
                  Todd
                  • 2 / 2
