    What is multithreaded rendering?
    6 Posts 3 Posters 889 Views 3 Watching
    • A
      Ands43
      Does it mean I am using more of the (cores) power of the core2duo chip, so it should be faster?
      • GaieusG
        Yes. Most renderers that can do multithreded rendering can use as many cores/threads as you have in your computer simultaneously. See two examples in these screenshots.
        • A
          Ands43
          Could one of the cores be broken and this lead to it struggling with multithreaded rendering?
          I rendered one drawing with it turned off and it took a long time but completed the rendering, I then rendered another image with MT turned on and it kicked me out, shutting down SU.
          • GaieusG
            Which renderer is it?
            • Chris FullmerC
              Do you have a reason to believe one of your cores is "broken"? (other than this incident)
              All my Plugins I've written
              • A
                Ands43
                No not particularly just this happens reasonably often and I also had some autoCAD problems, which the AC forum thought was RAM/videocard. I'm just guessing really.
                The renderer is podium.
