    What is multithreaded rendering?
    6 Posts 3 Posters 720 Views 3 Watching
      Ands43
      Does it mean I am using more of the (cores) power of the core2duo chip, so it should be faster?
        Yes. Most renderers that can do multithreded rendering can use as many cores/threads as you have in your computer simultaneously. See two examples in these screenshots.
          Ands43
          Could one of the cores be broken and this lead to it struggling with multithreaded rendering?
          I rendered one drawing with it turned off and it took a long time but completed the rendering, I then rendered another image with MT turned on and it kicked me out, shutting down SU.
            Which renderer is it?
            • Chris FullmerC Offline
              Do you have a reason to believe one of your cores is "broken"? (other than this incident)
                Ands43
                No not particularly just this happens reasonably often and I also had some autoCAD problems, which the AC forum thought was RAM/videocard. I'm just guessing really.
                The renderer is podium.
