    OBJ file manipulator = ?
    extensions
    3 Posts 2 Posters 658 Views 2 Watching
    • A
      agamemnus
      Hi guys,
      I am exporting my Sketchup models into .OBJ and .MTL files. I don't have any way to manipulate where the associated textures are stored, and what their filename is. For instance: sometimes, I want to use one texture for two different models, but Sketchup imports them into separate directories.
      Does anyone know of a good program that lets me manipulate this header info? Thanks!
      • TIGT
        @agamemnus said:
        Hi guys,
        The OBJ file says which 'object' get which material - open it in Notepad [osa] to read it...
        Open the MTL file and you will see the material name. color and file paths & folder name to the their textures [if any]...
        You can edit these and the specified files will be used instead.......
        • A
          agamemnus
          Thanks!
          facedesk
