    Transparent backgound
    11 Posts 4 Posters 885 Views 4 Watching
      Mr Tee
      Hi! Im making a flythrough using Proper animation and smooth step.
      Is it possible to render image sequnce with transperancy in the background, for layering in post?
        On a Mac, (I guess) it would be possible - it can render images with transparent background with native SU (though I am not sure about the animation).
        If you used other software (like 3rd party renderers), it would be possible to render the alpha mask for the animation, too - then it is just a matter of a batch routine in an image editor.
          Mr Tee
          Thank you for answer!
          No Mac here πŸ˜„ !!
          for this project i'm not using any 3rd party renderers.
          Soo there is no alpha support for sketchup?
          Can you get transparent background uisng styles?
            If you set your background to a specific color - say 'White' - and export all if the images as PNGs for the animation you can post process them in free tools like Gimp. There's a batch processor that might swap out that color as 'transparent' etc...
            Remember you need to remove the sky/ground and have suitable shadow casting set in each scene tab...
            I'm thinking of making a jar tool to do this - I already have 'gifxtractor(folderpath)' that takes a selected animated gif file and makes all frames as png files. I see something like 'pngwhite2transparent(folderpath)' where any png files in the given folder are copied into a subfolder called 'PNGwhite2transparent' and each is processed so any pure white pixels [255,255,255] become transparent... What do you think ?
              That would be neat, TIG.
                Mr Tee
                Thanks for reply TIG!
                The tool your talking about making sounds great, an easier to do!
                Thanks for advice about process image tool like Gimp, do u know any other free app that could to that?
                • Chris FullmerC Offline
                  Mr. Tee, what are you using for post?
                  You could do the animation export. Then do like TIG suggests and put white background on, no sky or ground. Then set the default front and back faces to pupr black, and turn on the display style that shows only front and back face colors and turn off edges and shading. You should be able to get a perfect black and white render of the video. Many post processing apps should be able to use that as an alpha map (I think).
                  Chris
                  All my Plugins I've written
                    Mr Tee
                    Thanks Chris!
                    I'm using after effects!
                    That method should work Iguess.
                    Its going to be double renders of everything though!
                    Thank you!
                      There s the blackout plugin by ThomThom:
                      http://forums.sketchucation.com/viewtopic.php?t=15790
                      Although it makes the mask reversed, it should be easy to convert them into negative. (Maybe we'd need a "whiteout plugin"?)
                      πŸ˜„
                        I have a batch tool ready [ pngwhite2transparent] - I'll post it soon...
                        EDIT: it's here http://forums.sketchucation.com/viewtopic.php?p=302827#p302827
                          Mr Tee
                          wow, cool!
                          Thanks!
