    How to model low-capacity?
    6 Posts 5 Posters 461 Views 5 Watching
    • G Offline
      giolangthang
      how to model low-capacity?
      i see models on 3dwarehouse very low
      why?
        Hi giolangthang,
        What do you mean by "low-capacity"?
          "Low-poly" perhaps?
          • G Offline
            giolangthang
            low size
            sorry, I speak english n0t well
            • numbthumbN Offline
              numbthumb
              If you are aiming for a "low size" model, extensive use of components, along with reducing arc/circle segment count could help.
              Also don´t forget a 'Purge Unused' operation: Window > Model Info > Statistics > Purge Unused
              Comfortably numb...
              • mitcorbM Offline
                mitcorb
                Add this to list: Delete internal faces and edges concealed within the model volume if not pertinent to final result. That means editing groups, components, or loose geometry intersecting, piercing, or enveloping other stuff.
