    Problem rendering.
    renderpluginsextensions
    3 Posts 3 Posters 816 Views 3 Watching
      MikMal31
      Hi all.
      I'm new to this forum which I find very helpful.
      I recently use vray in SU for my projects. I'm using a pc with system microsoft window XP Pro with Inter(R) Core(TM) 2 Duo CPU E7500 @ 2.93 GHZ and 2.00 GB of RAM.
      Actually I can render my project which is 36MB without problem,but when it is more than 36 Mb,it crashed each time, telling me that there is not enough space in my temp file and shut down after i click ok. I would like to know how can i prevent it to crash and render it with more than 36 Mb.
      I have purged my project and use low pixel texture but I notice that each time after i save it,the number of material increase. how can it be possible?
      your help is very welcome.
      Thanks.
      Mik.
        Report such errors to ASGVis support - along with the VfSu version you are using so they can investigate.
          Scostumatu
          Have a look to see if youve used any gif images in your textures. Sometimes this can be a hassle and cause issues.
          The amount of times Ive had this particular bug is enough for me to look elsewhere for a rendering program! Absolutely shocking considering the price Ive paid for the product.
          Look into the menue for vray within SU, it has an option there to force sydc all materials or something along those lines. Just try those also (avoid the first option whatever that is as itll force you to re apply all your textures).
          Hope this helps and good luck!
