    Need some snow
    16 Posts 9 Posters 3.6k Views 9 Watching
      tspco
      Anybody have any tips to make snow? We had our first measurable snow of the season,I have a model that I need some snow in, drifts, piles, and on roofs (but not 100% covered. If there is a snow plugin available that would be great!
      SU make 2017, /Twilight Render Hobby
      Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
      • numbthumbN Offline
        numbthumb
        EarthMover´s technique: http://forums.sketchucation.com/viewtopic.php?f=81&t=24663&p=211466&hilit=+snow+model#p211466
        Comfortably numb...
          If there's a snow plugin, could it be made so that one could also get rid of snow? We have too much. 😆
          Sorry. couldn't help it.
            tspco
            Sounds perfect, I will give it a shot!
            • shuraS Offline
              shura
              SDS can do some snow too - in this case the usually unwanted stretching can make the snow look wind-blown.
                tspco
                I tried earthmovers second method, using the Krill create mesh from points plugin, all was OK up until the Krill plugin either didn't work or I missed something. The progress bar went to 100% and no mesh, perhaps I didn't allow enough time, for it to work, but I am doing it again on another computer, and letting it sit for a while. Anyone try this recently?
                • soloS Offline
                  solo
                  Here is a simple way to get snow, note that this is just a basic method and for a better coverage I'd suggest tweaking it further using sculpting tools.
                  Okay, the scene is direct from 3D warehouse.
                  Copy the roof and paste as new geometry:
                  Paint it white, and using JPP (joint push pull) select all faces and pull up like this:
                  Now the fun part, using SDS (subdivide and smooth original version) subdivide the mesh, I used 3 iriterations:
                  Now that this is done, fit your snow to roof, feel free to modify and bend as needed, I use FFD, fredoscale, and basic scaling tools to get it to fit better:
                  So now you have basic snow, feel free to use sculpting tools (either BTM's tools or wait for new SDS2) to make it look more realistic.
                  http://www.solos-art.com
                  • KrisidiousK Offline
                    Krisidious
                    awesome Solo...
                    By: Kristoff Rand
                    • daleD Offline
                      dale
                      Pete, I really don't think I've ever met such a practical "out of the box" thinker. You keep coming up with the simplest ways to solve problems. This is a really smart way to do this. Thanks
                        tspco
                        Problem is I don't have SDS granted it is only 22 bucks, but that is s lot of cash for a tool when you are broke with no, or little chance for a return on your investment. Good idea though,
                        • shuraS Offline
                          shura
                          Maybe you can try round corners and after add some irregularities with Sculpt Tools?
                          • soloS Offline
                            solo
                            Absolutely, there is no right or wrong way, this way you can subtract from mesh to make irregularities. 👍
                              numbthumb
                              This one is free: http://www.smustard.com/script/Subdivide
                              Comfortably numb...
                              • shuraS Offline
                                shura
                                Oh, thanks for mentioning Subdivide. Its a good reminder as I have forgotten about it long time ago...
                                cheers
                                  SketchUpNoobie
                                  Found this plugin for 3ds Max. I don't use Max but saw this and just though it was pretty cool. If only they made a similar script for SketchUp . . . 😮 It's a bit pricey though. About $62 US dollars. 😒
                                  Bench with SnowFlow for 3ds Max.
                                  Let it snow, let it snow, let it snow!
                                  SketchUpNoobie: the complete noob in all things SketchUp.
                                  • pbacotP Offline
                                    Bump. I think back to the days of model challenges for Halloween and Christmas--which I enjoyed a lot but I don't think I ever felt good enough to join in. Maybe folks would like to make some Christmas cards and share them. Maybe we'll put snow on our current clients' house models for the Holidays and share with them (though the houses will be in California).
