    [Plugin] Compo Spray 1.4.2 Updated
    271 Posts 89 Posters 335.1k Views 89 Watching
      rachmatrf
      Hi Didier///
      THank you for this amazing plugin... You Rock...
      • V Offline
        voxdei_999
        first at all thank's for this useful plugin didier, but i'm having problems changing the default settings in the panel, simply i can't, why?
        i have a x64 xp os & the su v8 & of course the v 1.4.2 compo spray
        • Didier BurD Offline
          Didier Bur
          😲 😲 πŸ˜’
          Never heard of such a behaviour ! Are the fields blanks ? Can't you select items in the lists ? Can't you move the sliders ?
          Please let me know more details...
          Regards,
          DB
          • V Offline
            voxdei_999
            thank you didier about your interest, but i resolved the problem, i just update the internet explorer (i was the v6,'cause i prefer chrome) so now its ok. πŸ˜„ πŸ˜„
            anyway the problem was the sliders, they did'nt move, the other settings were able.. 😳
            • boofredlayB Offline
              boofredlay
              I keep getting 7 script errors every time I launch the tool. I have to close out as it is unusable. Hmmm.
              I just downloaded it today and unzipped it into the plugins folder.
              • brookefoxB Offline
                brookefox
                Reference is made to the related thread below where from these comments are copied:
                http://forums.sketchucation.com/viewtopic.php?f=323&t=16446&p=395138#p395138
                When spraying grass components onto a large area and I want to keep the numbers down the lowest available setting of 1% is still very much too high, so I make a request for percentages below 1.
                My work-round for this is to include within the component a large triangle so the spray density is thus limited and then edit this out of the component later. This works fine.
                Please see Eric's post above this one as he seems to need some assistance.
                ~ Brooke
                  Didier Bur
                  Hi Eric,
                  The 7 errors you are getting are all 7 variables "update_..." I guess. These are the seven sliders 'updaters' in the Webdialog.
                  So if 'update_pressure' and its friends aren't defined, this means that the Javascript script is either bad or not present.
                  Please check that you have a file named 'slider.js' in your Plugins/CompoSpray/JS folder.
                  Attached is the file that you need (you must unzip it) in case (for some reason) you don't have it.
                  Let me know if it works or not πŸ˜‰
                  Unzip in your Plugins/CompoSpray/JS folder
                  DB
                    boofredlay
                    Well you were right that file was not in the JS folder. However after unzipping it an placing it there I still get the same errors.
                    I am on a network if that makes any difference although I don't see how it would.
                      boofredlay
                      [flash=853,505:3hkk3iqb]http://www.youtube.com/v/lr2N_ZKpTqk&fs=1[/flash:3hkk3iqb]
                        Didier Bur
                        Do you mean that your Plugins folder (and SU itself) is not on the local machine ? I've never tested such a config.
                        Below are folders/files images so you can check your installation:
                        main CompoSpray sub-folder of Plugins
                        CSS sub-folder contents
                        Images folder contents
                        DB
                          Didier, how do you compile the path to the support folder? Do you use Sketchup.find_support_file('plugins') assuming the plugin is installed in the SketchUp plugin folder?
                          If you do, it's better to use File.dirname(__FILE__) to get the actual location of the plugin - allowing it to be installed anywhere.
                            boofredlay
                            Oh no, the plugins folder is on my local, the lic. is a network lic. and points back to a server.
                            My CSS, IMAGES and JS folders look the same but the Compo Spray folder looks like this:
                              TTskt
                              Great work on the plug-in.
                              Is there anyway to apply rotation in the 3 axes? Instead of just one.
                                Didier Bur
                                Not in this release, but this is a good idea... πŸ’­
                                DB
                                  TTskt
                                  @didier bur said:
                                  It would be great for some abstract worldds
                                  https://lh4.googleusercontent.com/-x0fk8vMAE3c/T6wzLEk7jmI/AAAAAAAAARw/etSeD1gX4OY/s628/cubos_Edo.png
                                  those where imported from a 3rd party, they lack acurancy and are bugged so solid tools wont work.
                                  • E Offline
                                    etong
                                    Obviously, some options in these webdialog are missing, any idea what I should need to do to avoid this from happening?
                                    Thanks!
                                    [xxl-img:1kq2bcwk]http://i305.photobucket.com/albums/nn233/etong75/CompoSpray.jpg[/xxl-img:1kq2bcwk]
                                      What version of SketchUp and what version of Internet Explorer do you have?
                                      • E Offline
                                        etong
                                        @thomthom said:
                                        What version of SketchUp and what version od Internet Explorer do you have?
                                        SU Pro 8.0.14346
                                        IE 9.0.8112,16421 64bit
                                          I moved (and merged to the original topic) your posts. Didier may monitor his own plugin topics but unlikely to discover your posts in the SU Bugs subforums (and apparently it is not a "native" SU problem).
                                          • E Offline
                                            etong
                                            @etong said:
                                            Thanks!
                                            [xxl-img:24j3z5f1]http://i305.photobucket.com/albums/nn233/etong75/CompoSpray.jpg[/xxl-img:24j3z5f1]
                                            SU Pro 8.0.14346
                                            Why are there missing controls in the Dialog Box?
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 13
                                            • 14
                                            • 7 / 14
