    [Plugin] Compo Spray 1.4.2 Updated
    271 Posts 89 Posters 368.5k Views 89 Watching
      rock1
      Can this plugin be tweaked so that in the components lists, the thumbnails of the components be
      shown, just like we see in the component window of the sketchup? 😎
      Signature removed by SCF Admin
      • L
        lapx
        DB,
        Thanks for such a useful program. I'm having more trouble with this one when I was having so much success with the old dialogue box 😞 I like the ideas though. I know it will work it self out.
        What am I doing wrong here? tried to populate by selection not working well, "shape is not available yet". What is the "shape" refering to?
        Is this tool similar to Chris's component on surface is similar?
        Once again, thanks!
          rachmatrf
          Hi Didier///
          THank you for this amazing plugin... You Rock...
          • V
            voxdei_999
            first at all thank's for this useful plugin didier, but i'm having problems changing the default settings in the panel, simply i can't, why?
            i have a x64 xp os & the su v8 & of course the v 1.4.2 compo spray
            • Didier BurD
              Didier Bur
              😲 😲 πŸ˜’
              Never heard of such a behaviour ! Are the fields blanks ? Can't you select items in the lists ? Can't you move the sliders ?
              Please let me know more details...
              Regards,
              DB
              • V
                voxdei_999
                thank you didier about your interest, but i resolved the problem, i just update the internet explorer (i was the v6,'cause i prefer chrome) so now its ok. πŸ˜„ πŸ˜„
                anyway the problem was the sliders, they did'nt move, the other settings were able.. 😳
                • boofredlayB
                  boofredlay
                  I keep getting 7 script errors every time I launch the tool. I have to close out as it is unusable. Hmmm.
                  I just downloaded it today and unzipped it into the plugins folder.
                  • brookefoxB
                    brookefox
                    Reference is made to the related thread below where from these comments are copied:
                    404 Not Found
                    (forums.sketchucation.com)
                    When spraying grass components onto a large area and I want to keep the numbers down the lowest available setting of 1% is still very much too high, so I make a request for percentages below 1.
                    My work-round for this is to include within the component a large triangle so the spray density is thus limited and then edit this out of the component later. This works fine.
                    Please see Eric's post above this one as he seems to need some assistance.
                    ~ Brooke
                    • Didier BurD
                      Didier Bur
                      Hi Eric,
                      The 7 errors you are getting are all 7 variables "update_..." I guess. These are the seven sliders 'updaters' in the Webdialog.
                      So if 'update_pressure' and its friends aren't defined, this means that the Javascript script is either bad or not present.
                      Please check that you have a file named 'slider.js' in your Plugins/CompoSpray/JS folder.
                      Attached is the file that you need (you must unzip it) in case (for some reason) you don't have it.
                      Let me know if it works or not πŸ˜‰
                      Unzip in your Plugins/CompoSpray/JS folder
                      DB
                      • boofredlayB
                        boofredlay
                        Well you were right that file was not in the JS folder. However after unzipping it an placing it there I still get the same errors.
                        I am on a network if that makes any difference although I don't see how it would.
                        • boofredlayB
                          boofredlay
                          [flash=853,505:3hkk3iqb]http://www.youtube.com/v/lr2N_ZKpTqk&fs=1[/flash:3hkk3iqb]
                          • Didier BurD
                            Didier Bur
                            Do you mean that your Plugins folder (and SU itself) is not on the local machine ? I've never tested such a config.
                            Below are folders/files images so you can check your installation:
                            main CompoSpray sub-folder of Plugins
                            CSS sub-folder contents
                            Images folder contents
                            DB
                              Didier, how do you compile the path to the support folder? Do you use Sketchup.find_support_file('plugins') assuming the plugin is installed in the SketchUp plugin folder?
                              If you do, it's better to use File.dirname(__FILE__) to get the actual location of the plugin - allowing it to be installed anywhere.
                              • boofredlayB
                                boofredlay
                                Oh no, the plugins folder is on my local, the lic. is a network lic. and points back to a server.
                                My CSS, IMAGES and JS folders look the same but the Compo Spray folder looks like this:
                                • T
                                  TTskt
                                  Great work on the plug-in.
                                  Is there anyway to apply rotation in the 3 axes? Instead of just one.
                                  • Didier BurD
                                    Didier Bur
                                    Not in this release, but this is a good idea... πŸ’­
                                    DB
                                    • T
                                      TTskt
                                      @didier bur said:
                                      It would be great for some abstract worldds
                                      https://lh4.googleusercontent.com/-x0fk8vMAE3c/T6wzLEk7jmI/AAAAAAAAARw/etSeD1gX4OY/s628/cubos_Edo.png
                                      those where imported from a 3rd party, they lack acurancy and are bugged so solid tools wont work.
                                      • E
                                        etong
                                        Obviously, some options in these webdialog are missing, any idea what I should need to do to avoid this from happening?
                                        [xxl-img:1kq2bcwk]http://i305.photobucket.com/albums/nn233/etong75/CompoSpray.jpg[/xxl-img:1kq2bcwk]
                                          What version of SketchUp and what version of Internet Explorer do you have?
                                          • E
                                            etong
                                            @thomthom said:
                                            What version of SketchUp and what version od Internet Explorer do you have?
                                            SU Pro 8.0.14346
                                            IE 9.0.8112,16421 64bit
                                            • 13
                                            • 14
                                            • 7 / 14
