    Vray for sketchup bug
    renderpluginsextensions
    2 Posts 2 Posters 967 Views 2 Watching
      andranaita
      I am using the new vray for sketchup 7 pro, on Mac OS, and i have a problem.
      When i am editing a model previously created on a Windows operated Sketchup 7 pro, that has several groups and material created with Vray material editor. It is a realtively big model. Vray will only render it after i use the debugging options from the plugin, and regenerating all materials.
      Is there any plugin or method to render without regenerating materials? Because if i don't do that, it doesn't render at all.
      Thank you
        Report bugs and issue to ASGVis. It's not very likely they'll find it here.
        Also, please include the version number of VfSU - that helps in diagnosing the issue, as then one can determine if it's fixed in a newer version or a beta.
