    Show hidden edges
    3 Posts 3 Posters 352 Views 3 Watching
    • L
      layne
      by holding option + Shift with the eraser tool I can un-soften softened edges, but how do I un-hide hidden edges? option + Shift + eraser does not do it, so what does?
      • TIGT
        Menu > View > Hidden Geometry 'on'
        Select the hidden edges you want to make solid again.
        Use Entity Info > un-check 'hidden' [increase the dialog's height so you see all of the the check-boxes if needed].
        Alternatively set some shortcut keys to Hide [H] and unHide [H+Shift] and use those...
        πŸ€“
        • Jean LemireJ
          Jean Lemire
          Hi folks.
          If you want to quickly unhide all edges, you can also use Menu Edit --> Unhide --> All.
          Just ideas.
