    Hyperbolic Roof with rafters... is there an easy way
    9 Posts 5 Posters 992 Views 5 Watching
      redinhawaii
      An example of roofs Picture 118.pngI can get the shape with soap skin ruby, I need to model the rafters,
      I did this portion by hand, is there an easier way to make the rafters, then automatically rotate them as needed to fit to this
      hyperbolic shape?Picture 117.pngPicture 116.pngWhat I seek to model.
      • jeff hammondJ Offline
        jeff hammond
        hi red.. see the video for one fairly simple method
        [flash=853,505:2twcgaum]http://www.youtube.com/v/BjMYzPW4GIg?fs=1&hl=en_US&color1=0x2b405b&color2=0x6b8ab6[/flash:2twcgaum]
        dotdotdot
          Another great method, Jeff.
          For free you could use Chris Fullmer's Perpendicular Face Tools to put a copy of the rafter section at the end of each line and use either Follow Me or Push/Pull to extrude them. Maybe not as fast but...
            redinhawaii
            Jeff,
            I want to thank you so very much for this expert reply, I am amazed at the concise and clear explanation on how to do this,
            I am really impressed. Thanks.
            I got a lot of learning to do, and some model making.
            Very supportive insightful reply.
            You time and effort is most appreciated.
            aloha
            red
              jeff hammond
              @redinhawaii said:
              Jeff,
              aloha
              red
              glad it helped..
              "You time and effort is most appreciated."
              the thing with these videos is that they're actually very short to make πŸ˜‰
              in the past, i've tried to do step by step skp's but they end up taking an hour or two just to type up and they're still not really clear.
              i'd rather just point at something and talk about it πŸ˜„
              dotdotdot
              • O Offline
                otb designworks
                Hey Jeff, great video, thanks for that!
                What screen capture software are you using? I have been using Screenium for a while now and it seems like your motion is smoother than what I am doing. What I really liked about Screenium was that I could make a custom window at a specified resolution and then place that window anywhere on either of my monitors. Super handy as I make all my animations 720p and having my screen captures the same size helps a ton when I get to video editing in Final Cut.
                Thanks again
                Cheers, Chuck
                OTB Designworks is on Youtube
                • bmikeB Offline
                  bmike
                  Nice. Thanks for the vid!
                  mike beganyi design + consulting llc
                    jeff hammond
                    chuck,
                    i use iShowU
                    http://www.shinywhitebox.com/ishowuhd/main.html
                    i demoed this and screenium at the same time (when screenium was still in beta) but ishowu won.
                    it does what you're talking about with the custom sized window that can be placed anywhere you'd like. (though i just use the presets.. this one is the youtube HD 720p preset). the pro version has some integration with Final cut but i'm not sure what exactly that means as i have neither the pro version or final cut πŸ˜„
                    dotdotdot
                    • O Offline
                      otb designworks
                      Yeah, I tried ishowu as well; I can't remember why I went with Screenium instead. Thanks for the info.
                      ***thread hijack off ***
                      Cheers, Chuck
