    Lost Window Menu Item
    layout
    4 Posts 4 Posters 1.2k Views 4 Watching
      redinhawaii
      I am working away on a complex, (takes a bit of time to load, 10 minutes) model,
      I get into trying to change a "Shape Style", I go to the pulldown Window Menu, there it is, checked, but not visable, no where to be found,
      I do NOT want to close my multiple ongoing projects in LayOut, quite the program and restart.
      Is there anyway to "find" where that Window Menu" item might be hiding?
      I have closed the ShapeStyle, reopened it... alas.. not to be located.
      any suggestions, beyond closing and restarting?
      • dereiD Offline
        derei
        Similar things happened with Sketchup Window menus. It could be a common cause ... one of google is or should be aware, for future version.
        DESIGNER AND ARTIST DEREI.UK
          bjanzen
          Assuming Mac: Window->Arrange Panels.
          b
            Bert
            This could happen if you did worked on two monitors;
            that menu window could be displaying on the second monitor.
            Salutations (Best regards) Bert
