Lost Window Menu Item
I am working away on a complex, (takes a bit of time to load, 10 minutes) model,
I get into trying to change a "Shape Style", I go to the pulldown Window Menu, there it is, checked, but not visable, no where to be found,
I do NOT want to close my multiple ongoing projects in LayOut, quite the program and restart.
Is there anyway to "find" where that Window Menu" item might be hiding?
I have closed the ShapeStyle, reopened it... alas.. not to be located.
any suggestions, beyond closing and restarting? -
Similar things happened with Sketchup Window menus. It could be a common cause ... one of google is or should be aware, for future version.
Assuming Mac: Window->Arrange Panels.
b
This could happen if you did worked on two monitors;
that menu window could be displaying on the second monitor.
