Help with this 3d wall Panel
@kalu said:
Thank you Marian for the quick Tutorial I will try that. I attach the Vray displacement model that I use now.
Thanks for your quick and great tutorial.
PS. What is the SDS plugin for softness?
You're welcome.
SDS(Subdivide and Smooth)- It does what it says in the name, subdivides the polygons, multiplying them and then applies smoothing. You can clearly see the effect of SDS in the last part of my tutorial.
It does cost $20 dollars but it's worth it, maybe not completely for this project but I guarantee you'll need it on future projects where organic modeling is requiered. -
Play with vertices and edges to define shape then subdivide as needed, group before subdividing as then you can use crease tool for corners and that will enable you to stack panels without gaps.
How did you do that ely.
Imported jpeg, traced over the lines. grouped it??, then sub divide in sks is that this http://www.smustard.com/script/SubdivideAndSmooth
Looks good.
Register LoginAdvertisement
