    Objects translucent on zoom out
    5 Posts 2 Posters 407 Views 2 Watching
      babycody
      I have a few objects that when I zoom out I can see through the objects. For example I can see the sides of each step in a staircase through the side boards. I'm not talking about z-fighting, and the material is not set to be translucent. I am using the default style for Sketchup 8. There is plenty of space between the outside of the object, and the piece I can see through it. Does anybody know what causes this, and is there a way to fix it? Thank you for any help you can offer.
        It's probably edges bleeding through the faces from a certain distance. See a longer discussion about it here:
        http://forums.sketchucation.com/viewtopic.php?f=15&t=33136
          babycody
          You can see what I am referring to in the circled portions.
          http://i65.photobucket.com/albums/h216/babycody1/Warehouse/Warehouse.jpg
            Although quite small picture, it seems to be what I was referring to. After my last post with the roofs in the other post, there is a suggestion to hide those edges.
            You can somewhat control this if you export in larger scale and later resize the image.
              babycody
              Thank you Gaieus. The Shift + Eraser Tool trick helped to hide most of it.
