    Window opens out of screen. Help!
    14 Posts 3 Posters 1.6k Views 3 Watching
    • dereiD Offline
      derei
      I can not find my layers window 😞 I suspect that is somewhere out of screen, but I can not take the screw driver to open my monitor and search for it πŸ˜›
      Ok, now seriously: I just updated my nvidia drivers and somehow I suspect it's related to it. in Window menu is activated. And if I maximize/minimize it from there, it doesn't show up.
      How can I retrieve it back?
      DESIGNER AND ARTIST DEREI.UK
        Jim
        Preferences > Workspace > Reset Workspace.
        • dereiD Offline
          derei
          Thanks, done. I recovered them.
          With one exception: SHADOWS. I can not open it 😞. I tried from Window menu and from Shadows toolbar button. The button doesn't stay pressed and the Shadow window is nowhere.
          Any suggestions?
            Jim
            I was beginning to think it was just me.
            • dereiD Offline
              derei
              @jim: you had this problem only with shadow window?
                Jim
                Yes, it occasionally goes awol. I have not actually had a chance to try my plugin in a "real emergency." It's not a permanent fix, but it just might keep you from having to close and restart SketchUp to find it.
                The usual way I fix it is to close and re-open SketchUp - that usually takes care of it. Have no idea why it happens, thoughm, or why it's just that one.
                • dereiD Offline
                  derei
                  I restarted it, I did reset workspace, but the shadow window can not be activated. I click on Window menu entry, but nothing happens. I should see a symbol there if it's opened, right?
                    Jim
                    The menus have 3 states - a check means open, a dash means open but shaded, and no icon means closed.
                    If it is open, you should see a dash or checkmark.
                    • dereiD Offline
                      derei
                      Well, I do not see anything, no dash, no check and I can click on it until my mouse gets broken... nothing happens 😞. I can try to reinstall, but if this happened it s sign that a problem is deep inside its guts. Dunno, I have the impression that Su6 was way more stable... I don't know what google did to new versions.
                      • honoluludesktopH Offline
                        honoluludesktop
                        Did you go and get the plugin at the bottom of his post on this?
                          Jim
                          Well, I don't think the plugin will work since it won't find a window that is not open.
                            Jim
                            Finally caught the Shadow Window bug on video:
                            It just wont open, and so my plugin will never find a window that isn't open.
                            http://i.min.us/idzrY4.gif
                            • dereiD Offline
                              derei
                              Any suggestion?
                                honoluludesktop
                                Jim, that's like my problem with "save animation" that refuses to work on one of my machines. At least you have a "work around". Sometimes I loose minimized windows under the task bar, but those can be found.
