    Window opens out of screen. Help!
    14 Posts 3 Posters 1.7k Views 3 Watching
    • dereiD
      derei
      @jim said:
      Preferences > Workspace > Reset Workspace.
      Thanks, done. I recovered them.
      With one exception: SHADOWS. I can not open it 😞. I tried from Window menu and from Shadows toolbar button. The button doesn't stay pressed and the Shadow window is nowhere.
      Any suggestions?
      DESIGNER AND ARTIST DEREI.UK
        Jim
        I was beginning to think it was just me.
        • dereiD
          derei
          @jim: you had this problem only with shadow window?
            Jim
            Yes, it occasionally goes awol. I have not actually had a chance to try my plugin in a "real emergency." It's not a permanent fix, but it just might keep you from having to close and restart SketchUp to find it.
            The usual way I fix it is to close and re-open SketchUp - that usually takes care of it. Have no idea why it happens, thoughm, or why it's just that one.
            • dereiD
              derei
              I restarted it, I did reset workspace, but the shadow window can not be activated. I click on Window menu entry, but nothing happens. I should see a symbol there if it's opened, right?
                Jim
                The menus have 3 states - a check means open, a dash means open but shaded, and no icon means closed.
                If it is open, you should see a dash or checkmark.
                • dereiD
                  derei
                  Well, I do not see anything, no dash, no check and I can click on it until my mouse gets broken... nothing happens 😞. I can try to reinstall, but if this happened it s sign that a problem is deep inside its guts. Dunno, I have the impression that Su6 was way more stable... I don't know what google did to new versions.
                  • honoluludesktopH
                    honoluludesktop
                    Did you go and get the plugin at the bottom of his post on this?
                      Jim
                      Well, I don't think the plugin will work since it won't find a window that is not open.
                        Jim
                        Finally caught the Shadow Window bug on video:
                        It just wont open, and so my plugin will never find a window that isn't open.
                        http://i.min.us/idzrY4.gif
                        • dereiD
                          derei
                          Any suggestion?
                          • honoluludesktopH
                            honoluludesktop
                            Jim, that's like my problem with "save animation" that refuses to work on one of my machines. At least you have a "work around". Sometimes I loose minimized windows under the task bar, but those can be found.
