    Model This: Sofas
    57 Posts 23 Posters 12.6k Views 23 Watching
      @tails said:
      What is/are SDS2, FFD and lines2cylinder?
      SDS2 is a soon to be released plugin by Whaat, but you can get SDS v1 here
      FFD is Free Form Divide which is available here
      Lines 2cyclinder is here
      Don't forget to thank the Authors 😉
        Ands43
        Thanks rclub24, I'll have a look!
        • jo-keJ Offline
          jo-ke
          are you subdividing each piece seperatly or do you make one group?
          I'm still in touble with the piping...
          my result looks like this:
          http://www.zz7.de
          • shuraS Offline
            shura
            Sorry Jo-ke, I missed your question 😒
            Subdivision is done on each part of the shell separately. After that they match as if they have been processed in one piece.
            Then you will find it easy to select the border of one of the parts to make the piping with L2C.
            From your picture it looks like you need to add the piping for the backrest, too. And maybe you could try to change the bevel on the bottom sides left and right, to reduce the bulging.
            Eric, thank you! getting good critiques from you really means a lot.
            cheers
            alex
            • olisheaO Offline
              olishea
              nice work guys....and good challenge. hats off solo.
              jo-ke...you know you don't need to subdivide a group? Just triple click anything and subdivide so you can make transformations directly to mesh without having the purple proxy .
              oli
              • jo-keJ Offline
                jo-ke
                Ah, thank you! I will try that.
                http://www.zz7.de
                • jarynzlesaJ Offline
                  jarynzlesa
                  super. just mark.
                  http://www.vizualizaceschodiste.mypage.cz/
                  • jo-keJ Offline
                    jo-ke
                    I'll wait for SDS2 and try that again
                    http://www.zz7.de
                    • K Offline
                      krash88
                      I was just wondering how Solo got his proxy to smooth so nicely... I just bought a copy of Artisan and hoped that the algorithm had improved, but I'm stuck with the same results as the original SD&S.
                      http://i109.photobucket.com/albums/n65/krash88/001.jpg
                      http://i109.photobucket.com/albums/n65/krash88/002.jpg
                      http://i109.photobucket.com/albums/n65/krash88/003.jpg
                      I have tried to smooth this same model using a proxy similar to what Solo has a few posts above with the same results. Am I doing something wrong?
                      • ely862meE Offline
                        ely862me
                        U need to make corners like this.
                        Elisei (sketchupper)
                        Come and See EliseiDesign
                        • K Offline
                          krash88
                          Thanks, I'll need to wait until I get back to work tomorrow to try that out. However, I have used Fredo's RoundCorner plug to bevel the same model into something a little more similar to Solo's proxy in post #6 in this thread. Still, I get something close to the same result that I posted earlier. I'm just looking for a more efficient work-flow and I'm wondering if that is indeed the final proxy or if more edges or any creases were added to obtain the final smoothed result. Thanks again!
                            Scostumatu
                            hi guys
                            can anyone do a small newbie tutorial on this?
                            Have just purchased artisan and would love to get my head around subd modelling in sketchup
                            Would be much appreciated
                            • FrederikF Offline
                              Frederik
                              Please take a look in the Organic Modelling section, where some tutorials already have been posted...
                              Cheers
                              Kim Frederik
                                Scostumatu
                                Thanks. saw that earlier but there isnt much there. I suppose I will wait until some of the gurus release some tuts 😄
                                cant wait!
                                  mwm5053
                                  Just been reading this and wondered how to do those corner. I tried Fredo6 bevel to now avail
                                  2011 iMac
                                  SU 2015 Pro, 2017 Make
                                  V2 Twilight
                                  macOS Sierra 10.12.5
                                  • ely862meE Offline
                                    ely862me
                                    Hi Walt !
                                    I mentioned the plugin I used in the message I sent to you the other day . I said it is Round corner plugin which can be found here http://sketchucation.com/forums/viewtopic.php?t=20485 . I used the bevel function .
                                    See attached for ideas !
                                    Artisan example by EliseiDesign.skp
                                    Also please visit this page http://sketchucation.com/forums/viewtopic.php?t=42938 .
                                    Have a nice day !
                                      mwm5053
                                      Thanks Elisei, that helped very much
                                      2011 iMac
                                      V2 Twilight
                                      • 3 / 3
