    Emissive layer in Vray
    renderpluginsextensions
    2 Posts 2 Posters 1.0k Views 2 Watching
    • F Offline
      Florida John
      Hi, I'm using Sketchup 7.1 pro and Vray ver 01.05.30 I am trying to render with one image not a tile effect. When i try to use a bit map in the emissive layer and unchecked the tile box, update showes image but render shows white image, when i leave tile box checked i see multiple images. I've playe around with this for sometime and now realize I need help. Anyone have the answer?
        I have not tried to uncheck the tile option.
        You probably want to check with ASGVis if this options works in VfSU.
