    Golden Ratio plugin?
    5 Posts 4 Posters 3.0k Views 4 Watching
    • xennonX Offline
      xennon
      I was wondering if there's a simple plugin out there that will divide a line into the Golden Ratio (phi)?
      If anyone cares to create one, it would be nice to have the option to swap the major/minor lengths ie: the placement of the dividing point.
      I know how to do it manually - geometrically, but my method is messy and tedious and involves using the circle tool to create construction arcs to find intersections followed by deleting surplus geometry.
      (omg - there's an idea ... a tool that creates circular/arc construction lines ?!)
      • massimoM Offline
        massimo Moderator
        Perhaps this plugin could help? Have not tried it.
        • xennonX Offline
          xennon
          Great! - Thanks for that. I knew there'd be one out there. I'll check it out.
            Jim
            Rick has a Golden Gauge plugin, also.
            (www.smustard.com)
              mac1
              BTW the rec tool gives you a golden ration inference
