    Spiral Extrusion?
    13 Posts 8 Posters 2.8k Views 8 Watching
      Jim57
      I'm trying to extrude a curve around a helix. I'd like it to be convex the whole way around. I tried TIG's EEby Rails and this is my result— the profile flattens and reverses as it wraps. I'd like it to remain normal to the rails.
      Here is a test run with a 360° helix, diverging as it rises. In Method 1, I used the semicircle as both Profile and Melding Profile, then the two helii (sp?) as Rails. At 90° and 270° the profile flattens and at 180° it reverses.
      In Method 2, I break the helix in half with a rightward semicircle at 180° and use this as my Melding Profile. It still flattens at 90°, which suggests that even if I break it further the profile will flatten somewhat.
      Is there a trick I'm missing, or is there another tool that will give me what I want directly?
      What I'm shooting for is a helix that wraps between 4 and 5 times, which is to say 1440-1800°. That's a lot of hand drawing— I could use a tool big time.
      Thanks in advance,
      Jim
      Extrude Spiral.skp
      • jeff hammondJ Offline
        jeff hammond
        use your 2nd method except make the helix your profile and melding curves... the 1/2 circles are the rails..
        [not tested but i think it should work out ?]
        dotdotdot
          jeff hammond
          yeah, it works..
          thing.skp
          dotdotdot
            Jim57
            You must lead a charmed life, Jeff, it doesn't work for me. In this model, I tried it with rails at 1080° and also at 900° (essentially, in the same or opposite direction).. The second way worked better but it still flattens out.
            Helix 2.skp
              jeff hammond
              oh, you still have to do what you described in method 2
              draw the semicircle every half turn of the helix.
              a little more work than doing it all in one shot but definitely a timesaver when compared to doing it all manually.
              i did the one earlier from scratch in 5-6 minutes so it's not too bad.
              dotdotdot
              • BoxB Offline
                Curviloft works for this quite well, using the middle one, follow given path.
                It does tilt the spiral slightly so if you want a perfectly vertical spiral it's best to make it with two full faces so that you create a tube, then you can just pop a cylinder up the middle and remove the inner half of the tube.
                Spiral Curviloft.skp
                • fredo6F Offline
                  fredo6
                  In a next version of Curviloft, there should be a 'sweep' method for this kind of cases.
                  Fredo
                  • shuraS Offline
                    shura
                    Good Idea, that boolean with the cylinder. Anyone mentioned already that the Draw Taper tool in Draw Metal has a similar function?
                    http://forums.sketchucation.com/viewtopic.php?f=323&t=33406drawtapertool.jpg
                    • majidM Offline
                      majid
                      [attachment=0:htg8prus]<!-- ia0 -->Curvi Sweep 1.gif<!-- ia0 -->[/attachment:htg8prus]
                      Fredo
                      taht'd be great Fredo ...seeing forward to see it... and thanx...
                        jeff hammond
                        Fredo
                        that'd be sweet!
                        dotdotdot
                          Aqualung
                          Thanks in advance,
                          Jim
                          Attached is a sample spiral using SpirixCode - 5 revolutions of a semi-circle with a scale factor of 2.0 using linear interpolation along the z-axis - Maybe this plugin will help create the shape(s) you're looking for?
                          http://sites.google.com/site/spirixcode
                          Sample Spiral created with SpirixCode
                            Jim
                            Hi Aqualung - is that your plugin? How about a tutorial?
                              Aqualung
                              Hi Jim - Yes, it's mine - The only tricky thing to using it is getting the entities in the right order - The plugin uses any un-grouped geometry as input - Additionally, any subsequent operation on the geometry (such as moving, scaling, etc.) potentially alters the order it is returned in a list - My workaround for this is to first create the reference geometry I need, put it in a group, and then trace any new geometry to be used as input.
                              To reproduce the spiral in question, create a circle (I used 12" for the diameter), position it where desired, and then put it into a group:
                              Next, create a semi-circle using the three-point circle tool:
                              For five turns of 48 segments each, 240 segments total are needed - In order to spread out the turns, a height of 120" was used along with a scaling factor of 2.0:
                              The result should be as shown below:
                              If you try to edit the original circle into a semi-circle and subsequently use it as input, you will prpbably end up with something like:
                              This is a result of modifying the geometry after it's created.
                              Aqualung
