    [Tutorial] Textured tiles with displacement
    renderpluginsextensions
    4 Posts 3 Posters 4.0k Views 3 Watching
    • DVERGERD Offline
      DVERGER
      Petite explication pour créer une texture tuile en utilisant le canal Displacement de VRay for Sketchup :
      Little explanation for creating a texture tile using the channel of Displacement VRay for SketchUp:
      En premier récupérer ceci
      First get this: http://forums.sketchucation.com/download/file.php?id=4851&mode=view
      ou page 3 de ce topic
      http://forums.sketchucation.com/viewtopic.php?f=18&t=241&hilit=projection&start=30
      Puis suivre tout simplement l'image suivante
      Then simply follow the image below:
      http://i67.servimg.com/u/f67/14/67/27/19/creati10.jpg
      (remplir aussi les noirs de la texture)
      Ne pas oublier de grouper la surface et de selectionner tout l'objet avant de poser la texture
      Do not forget to bundle the surface and select the whole object before applying the texture
      , indispensable!!!!!.
      Vous devrier obtenir quelque chose comme ça
      you get something like that:
      http://i67.servimg.com/u/f67/14/67/27/19/rendu_11.jpg
      • andybotA Offline
        andybot
        That looks very nice. What is the displacement amount in the options menu? Do you change any of the other options - edge length, max subdivisions? It would be good to know the values you use.
        -Andy
          The multiplier would have to have been changed, as a multiplier of 1.0 means 1" displacement. A nice trick to set up displacement for metric values is setting the global multiplier so that the local values relate to your model units. If you work in mm then use 1.0 / 25.4
          • DVERGERD Offline
            DVERGER
            I did not change the value unless the multiplier.
            And I blur the displacement map.
            I work in cm.
            My values :
