    Blue Balls
    39 Posts 17 Posters 5.6k Views 17 Watching
      SketchUpNoobie
      That's a load of balls Pete!
      Nice render though Pete. 🀣
      Edit: Hmmm. There's no one in the reflection taking a picture or anything. πŸ˜†
      SketchUpNoobie: the complete noob in all things SketchUp.
      • boofredlayB Offline
        boofredlay
        Nice rendering Pete. You sure do have a lot of balls. Mine are 3'-9" in diameter however. How big are your balls?
        • soloS Offline
          solo
          My balls are huge!!
          http://www.solos-art.com
          • jeff hammondJ Offline
            jeff hammond
            was wondering if the thread was deleted or something by nah, it's still there
            http://forums.sketchucation.com/viewtopic.php?f=81&t=18668
            dotdotdot
              boofredlay
              Ok Pete, you win again πŸ’š
                SketchUpNoobie
                May I ask a serious question? Why would one model his bal-, er, ornaments so large. Seriously though. I would like to know what is the advantage to having larger-than-life models. Would someone please enlighten me. πŸŽ‰
                • soloS Offline
                  solo
                  John, I jest, I shrunk the person.
                    SketchUpNoobie
                    So they are really about 2"-3" in diameter? Gotcha'. 😳
                      boofredlay
                      Actually I did draw mine over 3 feet in diameter. I wanted to have a real smooth mesh and when you draw small objects sometimes SketchUp cannot fill in the polygons. Sometimes it is better to model large then scale it down, sometimes.
                        SketchUpNoobie
                        Ooooohhh K. Now I get it. Thanks.
                        • mitcorbM Offline
                          mitcorb
                          An unfortunate workaround in my opinion.
                          Units are arbitrary measures.
                          You could conceivably set inches at 100 times what Sketchup has it set. Same with metric.
                          • olisheaO Offline
                            olishea
                            cool eric, tinsel looks great! i think ball would look even better with a coloured mirror finish and a night-time city hdri. merry christmas!
                            lots of free ones here http://www.smartibl.com/sibl/archive.html
                            oli
                            • N Offline
                              notareal
                              Eric, that tinsel is great. Maybe some "bold" material like http://www.thearender.com/forum/viewtopic.php?p=30463#p30463 could fit in scene too.
                                boofredlay
                                Wow, I never knew about those textures. Thanks.
                                  boofredlay
                                  As promised Here is the published tutorial
                                    troyhome
                                    Great project and very helpful tutorial!! thanks so much πŸ˜„
                                    IOviz.com
                                    SU Pro 2024 PC
                                    • V Offline
                                      Vicspa
                                      I followed your publication Boofredlay, eveythings works just fine except that the tops of my fur comes out pointy instead of square as your sample. where am I going wrong?
                                        boofredlay
                                        Nothing if you selected "fur_instance" in the "Make by Component" field. This makes the "blades" a component. Now all you have to do is edit that component and make it look like you want. In my case I just squared off the end and made the whole blade just one face.
                                          boofredlay
                                          As lovely as they are I would like to see SU output too, if possible?
                                          Here you go Rich.
                                          Here are some views, one with the whole setup and another with just one piece of garland along with the ball. I changed the background to red so it shows up better.
                                          • 2 / 2
